Configures an association ACL policy. This policy defines a list of devices allowed or denied access to the network.
association-acl-policy <ASSOCIATION-ACL-POLICY-NAME>
                         <ASSOCIATION-ACL-POLICY-NAME>  |
                         Specify the association ACL policy name. If the policy does not exist, it is created.  |
NOC-NX9500(config)#association-acl-policy test NOC-NX9500(config-assoc-acl-test)#? Association ACL Mode commands: deny Specify MAC addresses to be denied no Negate a command or set its defaults permit Specify MAC addresses to be permitted clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal NOC-NX9500(config-assoc-acl-test)#
| no |
                         Removes this Association ACL Policy  |
